Bosch SMV53A00gb/03 failed after install
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Bosch SMV53A00gb/03 failed after install
  • #64711
    cornwell40
    I inadvertantly left the salt cap off after initial fill up (day doing accounts then a tricky install head a little fried to say the least 🙁 ) so hopefully that hasn’t caused the problem.
    On first test after install, select programme and it drains as normal, fills nearly to wash level then beeps, drains and shows a tap sign in the display.
    The customer is Mr Fussy , charidee golf, round table, pringle and farrah man so, to say the least, I just want this one out the way. Already had to knock him money off as sales at Swift told me this was a s/s base and not polynox 👿 .
    Any ideas???
    Tony
    #357861
    ray.t
    Re: Bosch SMV53A00gb/03 failed after install
    Hi, I had one like this that was connected to a cut in tap. I found that the tap even though it looked fully open wasnt letting very much water through.
    Ray
    #357862
    cornwell40
    The thought had crossed my mind as the tap is fairly stiff to turn off/on. The machine is fairly slow to fill, but is almost to level when the programme aborts.
    Tony
    #357863
    ray.t
    Not 100{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} on this mate but is it possible that it has a time to fill in and if it doesnt get to the right level in that time it will abort?
    #357864
    cornwell40
    Had to get Bosch out, quoted seven days originally,even with a brand new unpaid appliance, Swift intervened and got two days(thanks Swift Sales ;-)). Turned out to be faulty flow meter/ tank.
    Tony
