Bosch SMV53M00GB Dishwasher Error Code E14
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Bosch SMV53M00GB Dishwasher Error Code E14
  • #89824
    jontymox
    Wondering if anyone can help with the above problem?
    The above error code relates to a reed switch fault, although remains after I have renewed it.
    The dishwasher empties, fills for a minute or so before aborting the cycle, beeping and displaying E14
    The twin electrical connection plug looks fine, as does the wiring although I haven’t delved deeper yet, as unsure where to investigate further.
    jonty
    #442674
    Gary59
    Re: Bosch SMV53M00GB Dishwasher Error Code E14
    I have changed a couple of side chambers on these type of models for various faults like these, often for not taking water, poor pump out etc. look for any signs of blockages in it.
    #442675
    nomadPaul
    Make sure the wheel behind the reed switch is spinning freely and that there is sufficient water pressure. I’ve also had to fit a second new contact (flow rate ) on a couple of occasions with the initial one being faulty.
