“the heating element was open circuit”. You and nearly everyone else with these things!
“After a while it continues to run” But does it run to the end / finish and has the machine actually pumped out? Only ask because the wires to the outlet / drain pump might not have been refitted or not clipped- you normally have to disconnect these wires (depending how you change the heat pump wash motor i.e. the hard way or the easier way) in order to fit the new heat pump least when used to work on these things.I presume the thing actually heats up now? If not best check those wires are all refitted too. Heat pump wash motor should be part number 00651956 via Bosch site at a moderately depressing £132.65 (keep your receipt they are apt to fail again: my record stood at under 5 minutes!!!).
