Bosch SMV69T10GB
  • #84392
    turbodry
    Hi everyone ,has anybody out there got an answer as to a Bosch SMV69T10GB built in dishwasher that just flashes check water light and rinse aid lights when switched on. No water in base, pumps free and connections all ok. Nothing appears in display and won’t do anything.
    Cheers
    #425548
    aqualectric
    Re: Bosch SMV69T10GB
    Had one with this fault just last month. Traced it to a faulty main control module; (had a blown triac) – no display or anything; just showing ‘check water’ light and one other light. Pump ran when the safety float was lifted. That was all.
    Make sure the new module is configured – no point in going any further if it’s not as no software is available outside BSH. Also familiarise yourself with the ‘language set up’ procedure before you go to fit it……. modules default to German on the screen unless you manually set it to English.
    HTH,
    Steve.
    #425549
    turbodry
    Great thanks for information sounds like Bosch “quality” modules again.!
