Home › Forums › Public Support Forums › Help And Support › Dishwasher Help Forum › Bosch SMV69T10GB/18 integrated dishwasher ends cycle with light on and 15 mins to go
- This topic has 6 replies, 2 voices, and was last updated 4 years, 4 months ago by
tgr.
November 15, 2021 at 11:20 pm #100246
tgr
ParticipantThis dishwasher is 11 years old and has been faultless until now.
The auto programme lasts 2hrs 30 according to the dash on the inside, but once the various cycles have concluded the programme seems to ‘hang’ in the final drying phase.
Same thing on shorter programmes e.g. glass. I come back to the dishwasher long after the programme should have finished and the dishwasher should have turned itself off, to find the red indicator light still on and about fifteen minutes still to go.
Dishes are still perfectly cleaned, water is heating as normal, no other warning signs.
I’ve tried all the usual things of several rounds of dishwasher cleaner, citric acid, and cleaned the filters regularly and often (they’re spotless anyway). I now do a three second reset every time to complete the programme, but I’d rather the thing worked as designed.
What should I investigate? Many thanks in advance
November 27, 2021 at 11:29 pm #479842tgr
ParticipantIt occurred to me that it might be the door lock problem occurring when the hot rinse phase of the programme causes thermal expansion. Is that plausible?
November 28, 2021 at 5:22 pm #479843electrofix
Moderatoronly if when you find it stopped you can close the door and it continues
November 28, 2021 at 6:07 pm #479844tgr
ParticipantThanks Dave I know I can close the door but I haven’t waited for the programme to finish. I’ll do some checking
December 1, 2021 at 10:42 am #479845tgr
ParticipantUpdate: mid-cycle the control panel now only shows a simultaneously flashing red light on the symbols of the tap and rinse aid. It won’t reset, either
December 1, 2021 at 11:36 am #479846electrofix
Moderatorif another member has Bosch tech access they may be able to advise but Bosch wont tell you what this means and i have no idea
December 1, 2021 at 12:48 pm #479847tgr
ParticipantOn closer inspection, the cleaning water didn’t drain from the machine. I siphoned it out and checked the movement of the drain impeller but it can move freely. The machine is currently inoperative as it won’t allow me to reset and begin a new cycle
