bosch smv69t30gb/73 lights flashing
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries bosch smv69t30gb/73 lights flashing
  • #99073
    mikehha
    could anyone shine a light on why the tap and rinse aid light are flashing ( no water in bottom heater on pump ok ) just flashing no break and you cant do anything apart from turn it on and off. holding the reset it dose nothing even if you hold up the flood switch it dose not bring on the pump. also is there a reset or test program . thanks
    #474923
    the flashing rinse light just means there is a technical fault
    and bosch tech can be hard to find
