Re: Bosch solder-in brushes. WFM3030GB/04 what size please?
Martin, I had a rummage through my box of brushes and came across some which are of those same dimensions, i.e. 8mm x 6.4mm and I cannot believe that is what will be in this Bosch motor when I finally get back to it. The ones I found were for a Black and Decker power tool.
Either you are ‘avin a larf or you are losin’ yer marbles. Now please admit that your response was less than well studied, to put it politely as I can. 🙂
Mike.
