Home › Forums › General Trade Forum › bosch spares
- This topic has 17 replies, 9 voices, and was last updated 3 years, 4 months ago by
mikehha.
November 14, 2022 at 3:44 pm #101348
mikehha
Participanthave bosch changed there packaging only just order a couple of dishwasher heat pumps from qualtex and they look like patten and there is no thin jubilee clip in there.
November 14, 2022 at 8:51 pm #484405SWERV
ParticipantI had one a few weeks ago. Ordered from Qualtex and the packaging was suspect, also there was no clip in the box.
There is something quite wrong if they are supplying pattern parts when you have ordered and paid for a genuine part.
I have been so busy that I never got round to querying it.November 14, 2022 at 8:51 pm #484406electrofix
Moderatorwhich one is it ?
November 14, 2022 at 11:46 pm #484407stratfordgirl
ParticipantYour suspicions are correct. Bosch heat pumps all come in brown paper taped boxes, scrunched paper inner packing, worm drive clip and labelled with the usual “Genuine” branded BSH label. Most distributors have dabbled with passing off pattern or OEM as genuine on selected lines for years, most often for elements and door seals, but occasionally other parts, so this is nothing new, though it is rare for Bosch items, as the packaging is so consistent.
November 15, 2022 at 9:15 am #484408mikehha
Participantpump no 12014980
November 15, 2022 at 10:13 am #484409electrofix
ModeratorQulatex pic just shows just motor
Aswo shows motor and clip
connect shows just motor
bosch website shows clip
If it was me i would expect clip to be in a gen box. I have to add clip to use pattern parts
November 15, 2022 at 12:07 pm #484410mikehha
Participantthey just don`t look right dave! I suppose they could be buying in bulk to keep the prices low and then repacking but that dosen`t excuse why the jubilee clip is missing?
November 15, 2022 at 8:47 pm #484411kaibart
ModeratorWith the bosch heat pumps u not need to change the clip and they can be done from the front without removing the dishwasher if built in just smear a bit of rinse aid or coffee machine lubricant on and your way to go
November 22, 2022 at 5:27 pm #484412mikehha
Participanttried that they leak went back and changed clip all good.
November 22, 2022 at 9:32 pm #484413kaibart
ModeratorI do it day in day out never had 1 leak as work for bsh
November 22, 2022 at 10:39 pm #484414electrofix
Moderatordid it that way yesterday. checked and had no leaks so left it
if it does leak then will have to go back and fit clip but so far no probls
November 23, 2022 at 6:53 am #484415kaibart
ModeratorGood to hear that dave I always fit heat pump into water switch 1st as the heater part slips on the pump with no issues at all you just need to make sure that the pump sits flush on the lip so the hose off switch can’t go on any more
November 23, 2022 at 9:01 am #484416mikehha
Participantlooks like another try for me then!
November 23, 2022 at 11:11 am #484417mikehha
Participantspoke to no! emailed qualtex they are going to send the clips if they have them? but no reduction in price for the pumps, but I could return them if I wanted. Now thats not very good customer services is it.
March 31, 2023 at 12:43 pm #484418timdowning
ParticipantI queried this with Qualtex but just got told I had to buy the clamp. Disappointing that you know you are paying for a genuine but just getting the pattern version – I expected better from Qualtex.
