Power on, select prog, press start – the module clicks a few times , then dry light comes on.
Pump is clear, heat pump tests ok, but there was a small leak in base.
Cant get this to do anything but go direct to dry , dry light on i mean.
Is this an error code ??
Thanks .
Clive
