Having fitted a new heat pump it now has a strange fault. It fills, washes and heats, but having reached temperature begins to add water until it aborts with check water light on. This doesn’t happen every wash and I’ve only seen it by sitting and watching through several cycles. All connectors seem ok, and it Meggers ok too.
Any clues?
I’m wondering if it could anything wrong with the new heat pump, but don’t see how! The flow sensor doesn’t show as a spare on the Bosch parts list, so can’t replace that in hope. The customer only initially reported “no heat” fault but isn’t sure it wasn’t doing this before.
Everything appears normal. On the Quick wash cycle it does the main wash, drains, then fills a little, drains a little 3 or 4 times then fills and washes. It’s at this stage that I see water filling the heat exchanger about 1/2 way up then stops with check water light on. It has also added water to the tub. The machine is spotlessly clean, even the heat exchanger/drain section.
