Bosch SPS6432GB
  • #14942
    reaper
    E.Nr SPS 6432GB/06
    Dishwasher starts, initial pump out, stops and buzzes (fill solenoid) no water enters.Customer pours pan full of water in and machine does a wash and empties,repeats for rinses(marigolds and fairy liquid would be easier).The fill valve unit has two pipes from it, one to the filling matrix and a clear pipe presumably to drain the valve. How does this valve work and how do you access it-machine laid on its back two torx screws removed but the bottom only hinges forward a couple of inches(plugs and small float chamber unclipped from base).
    I might be asking some basic questions here but I’m retraining myself on dishwashers after a layoff of ten years and they aint any easier!
    Yes there is water to the inlet valve.
    #161414
    Re: Bosch SPS6432GB
    The fill matrix has some sort of blockage. The small hose going to the valve is a pneumatic shut-off if the overflow chamber is flooded.
    Cheers,
