Hello,
I’m wondering if it’s even worth taking this machine in for an inspection.
What’s happened is that it no longer draws water in other than an initial couple of seconds burst if it’s been totally drained (having turned it on it’s side and round a few times); and when I poured some fresh water in to rinse it through manually, water came out the bottom somewhere.
I have taken the side panel off to have a look and checked the various pipes and tubes as far as possible but there were no obvious blockages and I know the external hose is fine.
The machine is a good 6-7 years old at least and has been in a flat with tenants for a while so has hard a fairly hard life. For instance when I got it back from them I found the salt holder was very full so they had been overfilling it with salt.
cheers
Mark
