Usually fills for first cycle then drains and doesn’t fill again. Adding water allows it to continue but will sometimes continue to end of cycle, usually not!! I have changed the Inlet valve, checked micro switches and all the tubes and pressure sensor etc. on the left hand side. All pipes appear clear. Also removed and checked control module for dry joints, re seat of connectors etc.
Any ideas?
Yes the water pressure and flow are good, I thought the supply pipe might be kinking when I pushed the machine back in place so I have checked the flow and tested it pulled out. Thanks.
