Bosch SRS43A02GB/14 slimline dishwasher overfill
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Bosch SRS43A02GB/14 slimline dishwasher overfill
  • #27721
    Simon46
    This one when started drains ok, can hear motorized valve working and then fills until the overfill cuts in the drain pump.level comes down whilst continuing to fill so pump cuts in and out ad infinitum. The wash pump never starts. Can anybody help?
    Regards
    Simon
    #215331
    gegsy
    Re: Bosch SRS43A02GB/14 slimline dishwasher overfill
    Ere Simon
    You’ve not forgotten the most spoken about fault have you 😉
    The dreaded hose from pressure chamber to sump,pressure chamber itself and/or water matrix being gunged up:?:
    Failing that does it fill continually when draining? If so it may be the fill triac on the module that has blown. 🙂
    Simon46
    fills continuously.
    S.
    #215333
    gegsy
    Simon46 wrote:fills continuously.
    If during drain at beginning, then fill valve triac on module 😥
    Module 489716 @ £68.10 +VAT etc retail.
    Simon46
    sorry Greg fills continuously after initial drain. ie only when asked to fill. just doesnt stop. filter area fills up to just before it will leak out of door then drain pump kicks in and out(overfill protection). interestingly enough watermain has burst outside house lifting pavement up (not connected) 😯 .
    S.
    #215335
    gegsy
    Ok Simon
    Check top microswitch on Pressure Chamber for correct operation.
    Check module connectors also for scorched connections. 😀
    nomadPaul
    Does this model have a flow meter on the fill hose ? I havn’t got my laptop to hand to check but if it has , these can sometimes go faulty giving this fault
    #215337
    gegsy
    Hi Paul
    Couldn’t see the little devil, will double check 😉
    Simon46
    Not stripped yet due to it holding up sink and worktop with blocks of wood.
    will see when supported.
    S.
    #215339
    gegsy
    None showing on diagram so thats that out 😉
    Simon46
    ah simple. 263185 water regulator diaphraghm not operating microswitch. Will stop filling if manually activated. £16.88 delivered from BSH :D. Am having a good day so far. Also sold/fitted whirlpool doorboot i have had in stock for 6 yrs.
    S.
    #215341
    gegsy
    Told ya 😛 😆
    #215342
    Simon46
    Thanks once again Greg :worthy:
    S.
