Home › Forums › Public Support Forums › Help And Support › Dishwasher Help Forum › Bosch SRS43C12GB Slimline pump problem
- This topic has 21 replies, 5 voices, and was last updated 17 years, 1 month ago by
vegasking.
March 5, 2009 at 10:41 am #278976
ModeratorRe: Bosch SRS43C12GB Slimline pump problem
After you have removed the wiring connections, depress the tab circled below and twist towards the front.
March 11, 2009 at 8:13 pm #278977vegasking
ParticipantRe: Bosch SRS43C12GB Slimline pump problem
Thanks for all your help guys, I managed to split the drain pump but found no blockage, the impeller seems to be sprung is this correct you can turn it and then it springs then turn again etc. Have tried it again and it sounds like the pump is trying and going through various settings i.e. I can hear what sound like relays clicking in and the pump makes various noises.
Not used to not being able to mend things, but it’s looking like a new dishwasher.
Any recommendations, it has to be a slimline. Looked on Which? and they still recommend Bosch but after the palava I have had with this one I am not sure.
March 11, 2009 at 10:34 pm #278978Goatboy
vegasking wrote:Looked on Which? and they still recommend Bosch but after the palava I have had with this one I am not sure.
I’d recommend the Bosch too, or rather the Siemens version of it, with the 5 year guarantee. Then you don’t have to have anymore ‘palavas’ 😉
But first, I’d say…
Get an engineer to it! It sound fixable to me.
March 12, 2009 at 9:01 am #278979vegasking
Just to report back, I kept the pump off, ran water through the machine on a cycle, collecting the waste water as I went on and it all started sounding better. I put it all back together and it seems to be working fine.
Thanks again to all those who helped and yes goatboy it was worth looking at again.
March 12, 2009 at 9:16 am #278980Goatboy
:snig:
Though I must say, this sounds blooming dangerous…
vegasking wrote:…I kept the pump off, ran water through the machine on a cycle, collecting the waste water as I went on…
:eeek:
DONT TRY THIS AT HOME, OR ANYWHERE!
March 12, 2009 at 10:03 am #278981vegasking
Goatboy, don’t worry, I am an electrician. I fiitted an external hose to the drain and took the water outside. Thats why I don’t know what caused the problem. The dishwasher was plugged into a RCD the whole time, no water entered the base whislt the machine was on.
March 12, 2009 at 10:15 am #278982Goatboy
These are public forums, that anybody can read, and there’s alot of nutters out there!
Their safety comes first.
Ps. Glad you got it working, tis a good little DW 🙂
