Just been at a Bosch dishwasher drains okay then kicks into wash pump working with no water, i have checked the fill valve water getting to it and the coil is okay, i then checked the pressure chamber which only had the over fill switch fitted, i noticed a flow meter switch? on the inlet to the metering tank, does anybody know if this would cause this problem cheers Jj
