bosch SRS45E02GB/21
  • #58368
    timdowning
    Slimline dishwasher;
    Customer complaining of times extended & hanging on 1 minute.
    Transfer tube, heater etc all fine & tested. I put it on a quick wash and it fills, heats & circulates. I reset that cycle. And left it running on the longer Auto clean wash. This went through perfectly.
    Apparently since then it hasn’t worked, the cycle times have extended & the machine is hanging on one minute. (No water is present in the machine at then end, so I assume its not a drain error.)
    Would the turbidity sensor cause the above or do you think the module has gone AWOL.
    Thanks.
    #334341
    Re: bosch SRS45E02GB/21
    Turbidity sensor probably gunged up I would think. Advise running machine through with dishwasher cleaner to see if that sorts it first. It should not affect programmes other than ‘Auto’ though, Quick Wash for example, is a pre-set time only cycle not reliant on the turbidity sensor.
    Also a bad relay connection on the module and even slow fill times can end up showing 1 minute left on the display, both can be somewhat intermittent and worth considering.
