Home › Forums › Public Support Forums › Help And Support › Dishwasher Help Forum › Bosch SRS5602/2 not allowing water in.
- This topic has 8 replies, 2 voices, and was last updated 1 year, 2 months ago by
aris.
January 24, 2025 at 12:49 pm #103190
aris
ParticipantBit of an older machine – but has been good to me and reliable until now.
Powers on – and hums a bit – sounds like the pump is working, but no water going through. When I open the door, I hear what sounds like a gasp of air.
Is the solenoid gone? Any tips on what else to check before I open it up?
Thanks,
January 24, 2025 at 1:24 pm #492134electrofix
Moderatorassume is humming as soon as you turn on
sounds like the base is flooded
unplug and pull machine out. tilt it backwards very slowly to about 45 degrees.you should see water leaking on the floor. we do it slowly so we dont slosh the water onto critical components
after its leaks out put it back down and try it
January 24, 2025 at 2:12 pm #492135aris
ParticipantThanks for the response. I’ll give that a go. If it is this, what may have caused it? Any preventive maintenance I can do to prevent it from happening again?
January 24, 2025 at 2:23 pm #492136electrofix
Moderatorwell sometimes there is a leak into the base but sometimes they have a bad day and leak but wont do it again for weeks
all you can do is try
as a proffessional i remove the water and with covers off watch with a torch through part of a cycle to look for drips
January 25, 2025 at 9:25 am #492137aris
ParticipantTried this – nothing happened. To be honest, I couldn’t even see where the water might come out from after tilting.
I did sort it out though. I added water to the dishwasher, switched it on, then pressed the reset buttons. It emptied what was in there, and was able to start up again.
Based on this – what do you think the cause may have been? Stuck pressure valve?
January 25, 2025 at 11:35 am #492138electrofix
Moderatorcould be all sorts
badly placed plate forcing water past door seal, too much foam etc etc
have you checked the bars as blocked hole in the bars mean the rest are at a higher pressure and can push past seals. It also does not wash as good
January 25, 2025 at 12:45 pm #492139aris
ParticipantPardon my ignorance – what are the bars?
I am running it on a hot cycle bow with a quarter cup of citric acid to give it a bit of a clean. Bit of preventive maintenance.
January 25, 2025 at 12:58 pm #492140electrofix
Moderatorthe wash bars that turn inside. all holes should be clear. get seeds, glass and plastic stuck in them
January 25, 2025 at 2:17 pm #492141aris
ParticipantAh yes I removed and checked they are clear. They appear to be spinning too.
