Re: Bosch SRS5612GB/08 programming issues.
Scale blockage in fill matrix doesn’t sound good so presumably they don’t put salt in the machine? Heater must be scaled up and likely as not the turbidity sensor can’t see in the dark as a result. 🙁
But the delay timer not working smacks of not being coded correctly I’m afraid. 😥 Did you set the module up free of the fascia mount or whilst it was in position? If set up correctly it wouldn’t default to its original factory settings so no worries there. To be sure best get BSH to fax you a copy of the coding sheet I reckon. 😉
