Bosch SRV43M03GB/29 drain pump continuously running
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Bosch SRV43M03GB/29 drain pump continuously running
  • #84505
    DIYer
    Hi my bosch dishwasher is continuously running even when I open the door. I can only use it if I tip it forward each time to remove the water which is in the base. I have seen on the net there are certain things you can clean once the left panel is removed. However,how do I remove the left panel? Also I think dishwasher can be checked for blockage at the very bottom front of the machine but I cannot remove the cover. Any ideas how to? thanks
    #425810
    Washdisher
    Re: Bosch SRV43M03GB/29 drain pump continuously running
    Possibly matrix clogged.
    Unplug machine. Lower door and remove two screws holding front of left panel to frame. Not sure if there are screws on the rear of panel but if so remove these also. Panel should then be removeable – watch out for sharp edges! Possibly some gunk causing a microswitch actuator to push against the switch. Will be quite obvious if there is.
    #425811
    DIYer
    are the screws at the front of the left panel a special type – since none of my screwdrivers fit it?
    #425812
    They are Torx head screws so off to the DIY shop you need to go. T20 the most common size driver.
    #425813
    DIYer
    thank you!
