Bosch sticking in programme
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Bosch sticking in programme
  • #32797
    randomrob
    hi
    i’m having problems with a bosch sms4472/gb/20 dishwasher, it fills and drains ok, heats the water ok but keeps sticking on the rinse cycle ( the star at the end of timer knob), it does not do it every time but is pretty regular, i have replaced the timer and metering tank but still no joy…would it have anything to do with the regeneration valve?
    any help will be gratefully received
    cheers
    rob
    #236425
    clivejameson
    Re: bosch sticking in proggramme
    randomrob wrote:hi
    rob
    No, nothing at all….
    Other things to check are the float and it’s switch fitted into the metering tank, and the associated wiring for it where it enters the bottom of the door.
    When it sticks, what is it actually doing i.e. nothing/pumping out/ quiet ticking etc?
    #236426
    gegsy
    Yep agree with above but please unplug before attempting any investigations :plug: 😀
    clivejameson
    Yep agree with above 😳 😆
    #236428
    Re: Bosch sticking in programme
    The hose from the bottom of the metering tank to the sump in the middle used to clag up on these old fellas. Strange things used to happen as a consequence………
    Worth checking.
    clivejameson
    Seem to remember those hoses were good mouse bait too…i had one which was two ends still connected and nothing in between 😆
    #236430
    randomrob
    thanks guys, took the hose off and gave it a good clear out and has been working fine since…
