I need to replace the Mechanical Lock Assy (189410) on a WTL5500GB/01 .
That’s the gizmo that prevents the machine working if the bottom panel is not latched into place. It stops you closing the door and starting it up.
It’s not too obvious as to the procedure for removing the metal front panel and accessing this device? Would I be right in thinking that the control panel has to be removed first?
