Bosch T/D making scraping noise?
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Bosch T/D making scraping noise?
  • #82624
    WTE86308/GB-02. Very few of these round here so first one I have seen.
    Customer complains of a metallic, scrape-scrape-scrape noise.
    I could not hear any such noises on visit, any know problem areas causing noise.
    Also how do you release the front edge of the side panels, I had a look inside the left hand panel with it held open and everything looked in good order from there.
    #420432
    timdowning
    Re: Bosch T/D making scraping noise?
    If it was scrape,scrape, squeak I could help you…
    Normally removing the front fascia will reveal more screws.
    #420433
    Thanks Tim, just supposing it was scrape,scrape,squeak?
    #420434
    usually a coin or stone trapped between drum and front plate. small screwdriver run around the gap from inside the drum normally prizes it free.
    #420435
    Thanks for that Mark, will give it a go. If it works I will give you the 1st prise. 😛 :mrgreen:
