Bosch T/D WTA4408GB/01 Heating Element gone open circuit
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Bosch T/D WTA4408GB/01 Heating Element gone open circuit
  • #24758
    donkeyjacket
    I have a 27 month old unit which I suspect has been abused by the better half in the normal way; i.e. opening door when hot, abandoning before cooling cycle complete, overfilling etc etc. I have had to reset the trip stat on several occasions.
    Anyway, now it looks like the heating element has gone open circuit on metering, all the temp. regulators/trip stats are short when disconnected so no problem there. I believe it took out the mini-RCD on the ring when it went!
    I’ve identified the spare as part no 492159, Heater-element, price 72.50 GBP from the QuickFinder app. on bshappliancecare.com (total price including £6 p&p £79.55).
    I have a couple of Qs:
    Is the best/cheapest way to obtain the part?
    Fitting – when the rear access cover is removed, the element is contained within the mid-grey assembly hanging off the back of the drum. What’s the correct way to remove, fit and re-assemble? Can it be done without removing the whole assembly from the carcass/drum or not? If not, how is the assembly to be removed from the carcass?
    Many thanks in advance for the answers, guys!
    #203217
    gegsy
    Re: Bosch T/D WTA4408GB/01 Heating Element gone open circuit
    donkeyjacket wrote:I’ve identified the spare as part no 492159, Heater-element, price 72.50 GBP from the QuickFinder app. on bshappliancecare.com (total price including £6 p&p £79.55).
    You can also order this part at spares@ukwhitegoods.co.uk 😀
    All done from rear without any major strip down also please read here – http://www.ukwhitegoods.co.uk/modules.p … pic&t=4359
    Un-plug appliance if you are to attempt repair yourself or use the engineer link below 🙂
    Regards
    donkeyjacket
    Many thanks for the very speedy reply!
    I have mailed off for a quote to supply the part as recommended. Thanks once again.
    #203219
    donkeyjacket
    Part received and fitted, unit good as new (well nearly!). Will try to train better half in correct use of appliance this time.
    Many thanks again!
