Bosch T/dryer WTL5100GB/11 Does This Point to the Timer?
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Bosch T/dryer WTL5100GB/11 Does This Point to the Timer?
  • #25784
    laurenceuk
    This machine is only operating on half heat.
    The heater is fine. I have removed the reservoir and checked motor is ok, made sure the float switch chamber is emptied. All cut outs are ok as long as they are all `normally closed`.
    It appears that the heater cct through the timer is not switching the neutral – lives at both ends of `dead` element. When I switch to `half heat` non of the elements are on.
    Does this timer give problems? Just looking for re-assurance 😕
    Laurence
    #207568
    gegsy
    Re: Bosch T/dryer WTL5100GB/11 Does This Point to the Timer?
    Hi Laurence
    Email will help you 😉
    Da, s-ar putea (releele ar trebui curatate sau schimbate sau verifica placa pentru contacte reci)… dar si termostatul poate fi decalibrat… 😳
    Yes, could be (relays should be clean or even changed or look on PCB for burned marks, dry joints)… but also thermostat can be decalibrated… 😉
    Baron 8)
    #207570
    laurenceuk
    A new timer fixed the problem.
    Thanks for all your help
    Laurence
