Bosch taking to long?
  • #70671
    WFL2063GB-12
    Complaint that it is taking over 2 1/2 hours for a 40° wash.
    Heater, fill valves, drain, outlet hose all perfect.
    Set it to a 30° wash connected to my test plug and after nearly 15 minutes the heater had not switched on. All wiring checks out so my guess is a pcb fault.
    Does this machine work like the old Hotpoint WM machines and advance the programme after a period if it senses no rise in temperature?
    nomadPaul
    Re: Bosch taking to long?
    It will wait for approx 105 minutes before moving on for a no heat fault .
    #378655
    Thanks Paul, sounds like it is going to be expensive.
