Bosch TD leaking
Viewing 1 post (of 1 total)
  • #90431
    pmb
    Hi i am having trouble with a Bosch WTE84308GB17 which leaks from the front right corner (where the fan is). i have had all the panels off straight after a cycle to see where its coming from but can’t see where the water originates from, just that its wet there. I checked the heater panel, around door and condenser for damp. So far i have levelled it, removed fluff from pump water reservoir, checked heater for blockages, removed fluff from front fan, cleaned condenser and door seals. Has anyone got any other suggestions? i am stuck?
