Bosch TD | WTWH7660GB/07 | Water leak from Front RHS
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Bosch TD | WTWH7660GB/07 | Water leak from Front RHS
  • #103576
    neon_3SP_glow
    There is no blockage preventing the water pooling in the water drain tray at the back of the machine where the water pump.p is located. This machine doesn’t appear to have the narrow channel (known to block up with lint).
    I have shorted the sensor to trick the machine into thinking it needs to run the water pump, the water pump subsequently runs.
    However, unlike the old appliances, where the water would be pumped directly to the tank, this machine routes the water though another device called the ‘Outlet set drain set’ part number 00657920.
    Any help on what this device is, how it functions and/or what may be causing the water to accumulate around the condenser causing the leak front right hand side?
    Many thanks.
    #493782
    neon_3SP_glow
    * water leak is LHS not RHS!!
    #493783
    neon_3SP_glow
    Right! I got this one home this afternoon to investigate.
    It’s a self clean machine. The way it does this self clean is to dump the water held in the water tank (via a flap and solenoid) onto the front of the condensing unit. This is designed to disturb and remove any fluff/lint accumulating on the condenser grill.
    Part number 00657920 is responsible for diverting water to the water tank ready for a self clean, if the customer has the machine set up to drain the water out of the machine into a down pipe etc. It needs to reroute the water to the tank to be able to self clean.
    The machine was showing Care in the led display.
    This message will initiate relative to time when a manual care maintenance program is needed.
    As far as I can tell, the leak has been caused by fluff and lint against the seals in the front LHS window which allows access to the condensing grill.
    I’ve cleaned up all the seals/windows, ran a cp1 maintenance cycle and she’s a s good as new!
    Bravo!
