Bosch top draw moves?
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Bosch top draw moves?
  • #84826
    leedata1979
    Hi all
    I have a customer that has a bosch sms40a02gb/3 fd 9109 and heres the steps to my problem
    1. start a program
    2. fills ok
    3. pumps water to the top and bottom spray arm fine but then the top rack moves to the door and now the water comes out from the tube connection at the back coz the rack has disconnected from it.
    i have change the spray arm and connection to it and its not that.
    so i’m trying to work out if its the Altern.water distributor or the pump thats making the rack move to the door?
    any ideas
    kind regards
    #426927
    Allsorts
    Re: Bosch top draw moves?
    Have only ever had this fault once… The problem was that the dishwasher was not quite level
    #426928
    leedata1979
    hi allsorts
    checked that and was fine to
    #426929
    Allsorts
    Did you check that all the rotor holes were clear? as if not, there will be a build-up of pressure which will do what you are experiencing.
    #426930
    nomadPaul
    There is a rear rail modification where a rail is fitted to the rear of the appliance which stops the rear wall from flexing , therefore ensuring a good connection between the top basket and rear connector.
