WOK2001GB/05 has an open circuit coil on the double cold fill valve. Has anyone changed one of these and can offer any advice as it is far from obvious how you get the thing off? 😕
Thanks Chris. I normally just change the coil but in this case I don’t have anything that will fit. I will keep the good coil off this one though so if I ever get the same fault on the same model I will be prepared!
