I have a new Bosch WAQ283S1GB_WH. After the transit bolts have been removed some plastic covers are provided which are supposed to be fitted over the holes. I’m damned if I can get them in though, they just seem slightly too big for the holes. Is there some clever technique to get them in?
If you want to put them in, the larger one slides down into the recess first and the small one with the short length of plastic pops into the top hole.
don wrote:If you want to put them in, the larger one slides down into the recess first and the small one with the short length of plastic pops into the top hole.
Page 27 of your manual 😉
Thanks, I’d seen that, but all it says is ‘Insert the covers’. No amount of pushing/sliding will seem to persuade the largest part of the cover to fit into the large part of the hole!
