bosch tumble dryer
  • #33152
    cornflakes
    model wtl6102gb/02
    i need to visit this unit this afternoon
    client says “empty condense unit” is showing all the time, even after emptying and returning collecting dish, anf therefore no action.
    any quick ideas where to start
    merry xmas to all that read and a happy new year also
    graham
    Leicestershire
    #237614
    superfix
    Re: bosch tumble dryer
    Blocked hose from pump to water tray would be my guess.
    #237615
    cornflakes
    spot on with that one amigo….cured the problem
    mucha gracias
    saved me a lot of effort
    #237616
    superfix
    Aucun problème, content d’aider :tup:
    #237617
    cornflakes
    Had occasion to re-visit this appliance, i thought i had cured the problem with blocked pipe, unit was working ok when i left on1st visit.
    unit now not heating up or infact doing much.other than rotating
    what ever programme setting you select…unit runs for 30 to 40 secs and then anti crease/end light comes on.
    any advance on this one welcome
    many thanks
    Graham
    Leicestershire
    #237618
    robedoo
    saw this post from a while back, did you resolve? as i’m having same problem with WTL6103GB/01
    #237619
    robedoo wrote:as i’m having same problem with WTL6103GB/01
    Which problem , the first ‘Empty Container’ or the second ‘No heat’ fault?
    The first almost always the pump hose blocked. The second an NTC or overheat stat fault as a rule. But do please be more specific and I will see which magic wand I need to loan you. 😈
