Bosch Tumble Dryer
  • #69077
    WTV74103GB/04.
    Pick a programme, any programme. Within a second or so, lights 1,2 + 4 start flashing. I assume that this is an error code?
    I have checked the heater circuits (fine)and the thermistors(Reading in kOhms).
    Machine will not actually run and the lights will only go out if the selector is put back to off.
    Any thoughts welcomed.
    Thanks,
    P45.
    #373639
    nomadPaul
    Re: Bosch Tumble Dryer
    i think its an F:11 fault – (drying , iron dry & end LED’s ?) If its those 3 then you have either a main board failure or motor fault. Check all plugs on the board for fitting and if they’re alright , try unplugging the motor to see if that makes a difference.
    My own experience would point towards a board failure unfortunately. The new modules come with a coating over the electrical components so that suggests we’ve had problems with moisture ingress on the original boards maybe ?
