WTE84102GB/05
Drys normally for about 8 minutes then cuts out no lights.
Turn dial off and back on will start but then a relay clicks on board and machine goes dead.
Each start will enable various lengths of drying time from a few seconds to a couple of minutes.
Everything has been cleaned thoroughly (except for internal fan on motor) so there is good airflow and pump is working normally.
No fault codes are displayed.
Suspect the pcb but wanted others opinion and if known the room temp values of 2 sensors 600157 and 154166
Cheers Neil
