Bosch Upright Freezer with temperature problems
Home Forums Public Support Forums Help And Support Fridge And Freezer Forum Bosch Upright Freezer with temperature problems
  • #30946
    pscrub02
    Model GSU 3401 GB – Started with temperature problems weeks ago and will go no colder than -10. The temperature creeps up and then I press ‘super’ again, switch it on and off and the alarm will stop and it goes back to -10. I was searching for a new freezer when I stumbled upon this forum. Before I buy a new one, has anyone else experienced this? I did ask Bosch but the call out charges (before parts) put me off taking that any further, the freezer is 7 years old. Is it repairable? Any advice gratefully received, thanks.
    #229018
    nomadPaul
    Re: Bosch Upright Freezer with temperature problems
    have you tried defrosting it for 48 hrs and then switching it back on again ? If you look behind the grill at the top of the freezer compartment ( use a torch to look through the slats ) , can you see it all iced up ?
    The door being left open for a shorttime can cause the evaporator to slowly ice up and will cause temp probs . A complete defrost will , in most cases , clear the prob .
    Its worth trying it before you just dump the appliance .
    #229019
    pscrub02
    Thanks very much for the quick reply, I’ll certainly try that, it could save a small fortune!
