Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Bosch Vacuum
- This topic has 14 replies, 7 voices, and was last updated 20 years, 10 months ago by
Phidom.
May 24, 2005 at 9:53 pm #9773
ParticipantBosch Extraxx 17, E No. BUC11700GB/01 has no live getting to the brushhead motor circuit board. I’ve checked the switches etc in the handle and I think the fault might be in the microswitch which shuts off the brush when the handle is vertical. This microswitch is mounted in the main motor housing but I don’t know how to remove the white plastic bearing rings from the ends of this housing. Is anyone familiar with these cleaners as it’s the first one I’ve seen? 🙄
May 25, 2005 at 7:45 am #135769mbdas
ParticipantRe: Bosch Vacuum
Its a Vax upright Ive replaced a few motors in these both the vax and bosch versions I spray a little polish on the rings and push the spring loaded pegs in and gently easy them over never had a switch in the base faulty though just plenty of motors
Mark 🙂May 25, 2005 at 8:26 am #135770Goatboy
Phidom wrote:…has no live getting to the brushhead motor circuit board….
There’s a cut-out in the main body of the vac, on the front, behind the giant floor tool, tiny little button. This cuts out the brush-head motor when the brush-roll gets blocked.
May 25, 2005 at 9:12 am #135771SWERV
🙄 I’ve repaired quite a few of the vax, which are pretty much the same, and have had a bad connection in the 2 wires that go to the small pcb in the head unit. They normally break where the wire comes through into the head assy.
MervMay 25, 2005 at 5:55 pm #135772Phidom
Yes Merv, there is no continuity between the black wire from the cutout device and the black wire to the PCB whether the microswitch is in or out. It could well be an internal break in the wire from the microswitch to the PCB.
Thanks Mark, I will try the polish and see if it helps.Phil
May 25, 2005 at 9:43 pm #135773Phidom
It looks like Vax are trying to outdo Dyson in their quest for the most difficult appliance to dismantle and re-assemble. 👿 It was the microswitch, one of its spade tags had snapped off. I will have to order a new one (Part No. 417915 ?) but none of my supliers seem to keep it as a stock item, which usually means I have to wait at least a month. 😥
May 25, 2005 at 9:44 pm #135774BSH-MAN
Boro, you first! 😉
May 26, 2005 at 1:26 pm #135775superfix
Definately a broken wire from head s/w I’d say.
We send them back to MK workshop for repair/replacement,as apparently they are pig to strip down any further. 😈
May 26, 2005 at 4:17 pm #135776SWERV
🙂 They are a bit of a pig to dismantle, and as for getting spares don’t even go there.I have just told vax we are not being service agents anymore, because I am fed up of waiting months for spares!!!!(even belts and brushrollers).
May 26, 2005 at 4:25 pm #135777SWERV
We used to get our parts from GTA tel no.01159414436 don’t know if they could help you ,if you haven’t already tried them. The vax equivalent model is AVC1 and the part no. is 1-5-124880-00.
May 26, 2005 at 9:39 pm #135778Phidom
Thanks Swerv. I see this part is shown as in stock at Connect. I already ordered the Bosch one but they are not too expensive so I can order the Vax one as well. 🙂
June 2, 2005 at 11:58 am #135779Phidom
😥 The Vax microswitch arrived today and I started the long process of fitting it and re-assembling the machine. It is a changeover switch so you have to connect to the right 2 tags. I thought I had carefully checked against the old switch to know which 2 to use but I must have got it wrong as the roller motor now operates when the machine is vertical but not when angled over 😡 So its back to square one.
June 2, 2005 at 12:09 pm #135780Bryan
Don`t worry Phil it`s all in a day`s work 😆
June 2, 2005 at 8:25 pm #135781Phidom
Yes, all sorted now. 😀
June 15, 2005 at 12:39 pm #135782Phidom
Just as well I didn’t wait for the Bosch switch. The one I ordered, part No. 417915 arrived today and it’s not even the right switch, it’s the rocker switch for the main On/Off control 😕
