Hello,
I have a Bosch VarioPerfect WAQ243D0GB washing machine and I can’t close the door because the part of the interlock that is visible is in the way. I assume the part should normally be up unless the machine is doing a wash. Is there a way to quickly test whether it is definitely faulty? Is there potentially a way of unlocking it manually? I have a lot of washing up to do so I might just get a new washing machine as getting parts, etc. can be time consuming, just want to check if I am not missing anything obvious.
Thanks,
kreutz
