Sensor drying does work OK using the normal heat programmes on most fabrics. Low heat should only be required for more delicate synthetics and in cases like this using a timed dry setting is by far the best or only solution.
The symptoms indicate to me that there is no real problem here and adopting the solution above should be the resolve.
