Bosch very new W/D, door clicks but not locking
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Bosch very new W/D, door clicks but not locking
  • #96005
    pmb
    Bosch Washer/Dryer wvg30461gb/02. This a new type with brushless motor, squire latch,
    I have been to two of those in the last week, the door clicks closed then unlocks. It’s not the heater or interlock.
    other engineers have put this on topic but I don’t think anyone has said what the cause is, main suspect is the PCB.
    Any Bosch engineers out their who can help.
    #462041
    michaelnaylor1983
    Hi. Did you get anywhere with this. I have just been to the same model with the same fault. Fitted interlock but no success. Suspect PCB but it’s an expensive one!
    thanks
    #462042
    SteveATY
    Had a couple of these and on each occasion it’s been the joint between the wiring (to the door lock) and the PCB. To test my theory I stripped the PCB assembly and hard-wired the door lock – machine then worked perfectly.
    #462043
    michaelnaylor1983
    Thank you. I’ll let you know how I get on.
