Re: Bosch. VT59635 door hinge
It is tight getting at that band clamp screw I’ll grant you. I use an extra long shafted pozidriver. The hinge incidentally can be welded though it needs specialist welding equipment to do it.
A local haulage contractor owner had the same problem with the hinge on his V691. I removed the hinge for him. We then took it to his repair workshops (where they fix their own 40 ton trucks/diggers and cranes) Much to my amazement a guy there put the hinge in a vice, donned a mask and welded the crack back together and ground the excess weld stuff smooth again. A bl**dy miracle performed right before my eyes….! 😯
