Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Bosch W/D throwing TOC.
- This topic has 8 replies, 6 voices, and was last updated 17 years, 1 month ago by
Madmac.
February 11, 2009 at 6:55 pm #43401
Madmac
ParticipantWFT 8030 Washer dryer, push to reset TOC was triggered on this machine, reset it & tried machine with door open, seems to have good airflow. Told cust to try again & dont stop cycle mid way.. although she claimed she never does.. anyway, its gone again after a week :rolls:
Noticed an NTC poking into the airflow duct above door, is this the fella i want to be changing i wondered 😯 Thanks,
Eddie.February 11, 2009 at 7:03 pm #277149A1engineer
ParticipantRe: Bosch W/D throwing TOC.
had one or 2 of these with knackered water valve not letting any water in hence overheat and trip.
usual complaint is steam from drawer tho….
February 11, 2009 at 7:10 pm #277150PINKY
Lazy fan motor use to be quite common but more likely blocked condenser. Did you take of the hose @ the bottom of the condenser?
February 11, 2009 at 8:23 pm #277151Madmac
No, did’nt look at that hose, might try that then. Inlet triple valve was changed by my good self about 3 years ago, seems to be pulsing normally on dry. Blockage or NTC then? Anyone know resist values?
Thanks 4 repliesFebruary 12, 2009 at 8:50 am #277152Martin
Fluff blocked condenser for sure. 😉
February 12, 2009 at 9:42 am #277153admin
KeymasterRe: Bosch W/D throwing TOC.
Had one last week and it was was blocked with fluff……….
CANUFIXITFebruary 12, 2009 at 8:41 pm #277154Kentish
I would also check for pcb issues. Get the machine going on spin and see if the air coming through the ducting exhaust at the door seal is warming up. If the air is warming/getting hot then the triac is switching the neutral (dryer elements live both sides when not needed).
If I come across a Bosch style w/d that has tripped the TOC, after resetting and checking condenser and fan operation I always do a spin with door open.February 13, 2009 at 12:05 pm #277155Madmac
Thanks for the tips chaps, no callback on it yet but i await it with trepidation…. 😯 😯
February 13, 2009 at 12:08 pm #277156Madmac
Oh, sorry, fairly blocked condenser was found 😉
