Bosch w/dryer WVD24520GB/01
  • #68316
    razor
    Hello all , any bosch engineers for help please
    went to Bosch w/dryer WVD24520GB/01 FD8708 with f18 error , no blockages , hoses clear, drains fine , even changed pump.
    tried it on gentle dry , goes for about 5mins or so and comes up with F18, any ideas what else causing problem
    many thanks
    #370575
    timdowning
    Re: Bosch w/dryer WVD24520GB/01
    Did you look at the flow of water into the appliance as its drying? Could be valve related. (Did you insulation test the heater?)
    #370576
    razor
    Water was going in, maybe worth changing?, will check heater , as in the washer heater or dryer heater ?, the dryer was heating ok ,
    #370577
    timdowning
    The dryer element was heating but what was the insulation?
    It could be that too much water was going in, as in the restrictor has come out of position?
    #370578
    razor
    ok , thanks for help there , wil check these out tomorrow 🙂
