Hi Guys Looked at a bosch maxx 7 enr wae16161gr/08 it fills for about 3 secs then goes into fault mode with the 800 spin & water in tub lights flashing. Pressure switch & vipler hose seem fine. The double inlet valve (no hot European model) has one connector 3 wires 2 lives 1 neutral could be the other way round didn’t check, high resistance on one of the valves suspect this might be the problem but is that what the fault code is indicating. Thanks Mack.
