Bosch w/m Enr: WVD24520GB/04 stuck on 1 min left
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Bosch w/m Enr: WVD24520GB/04 stuck on 1 min left
  • #58532
    nospin
    Hi, THis machine is stuck on 1 min left. Can’t cancel wash. Unplugged machine for 5 mins and still locked out. Rinse plus light is on as well.
    #334828
    Re: Bosch w/m Enr: WVD24520GB/04 stuck on 1 min left
    Think there’s something about Bosch and heater element in relation to this. Try a search, TTE only, e.g. “Bosch + 1 min” or Bosch + stuck”
    Mike.
    #334829
    nospin wrote:Unplugged machine for 5 mins and still locked out.
    Interlock?
    #334830
    nospin
    Hi, bit late replying here. Tried everything on this. id the door lock and heater. I then looked at tech on bosch website and it said about the 1 min left scenario. It asked me if there was a power cut??? It turned out they had a powercut and someone moved the timer. It turned out that if someone moves the timer knob when the power has been lost, It comes up with 1 min left. Its to tell you that your not on the right program. As i went through the tech info, the tenant came in and moved the timer back to the original program. Lol Why didn’t he do that b4 he rang me? The stupidest faults i’ve ever had. Not for 1 min did i think the timer had been moved. If that happens again, i will go through every wash until it clears. Thanks anyway cos i’ve learn’t a lot. Its been emotional!!! 😯
