Bosch w/m won’t start
  • #27434
    zimmatt
    I have a Bosch exxel1200 (wfo2465gb) washer and it went bang ! My wife said it was a mechanical bang rather than an electronic one but this should probably be discounted as concrete evidence.
    The lights come on and the door locks, the display is functioning as normal – even counting down in time but nothing happens. There is a faint hum from somewhere in the m/c.
    Can anyone offer advise please – two small children generate a lot of washing !!!!
    #213993
    gegsy
    Re: Bosch w/m won’t start
    If you turn the drum by hand from inside, does it seem to turn with minor force?
    zimmatt
    yes – the drum spins relatively freely
    #213995
    gegsy
    With this particular fault, you would benefit from an engineer call in all fairness.
    Please use the link below 🙂
    zimmatt
    ok thank you – i thought that might be the case.
    Update for those that might have this problem in the future.
    Pump was jammed with a screw, cleared screw and it works.
    Was just lucky the screw didn’t do any greater damage to the fins.
