Re: Bosch WAA24160
Muv wrote:Is it a simple drum out job, like a good old fashioned Hotpoint…. Or not
:hmm: All depends if you like a challenge?
Drum out the front job, then cut off the locking tabs holding the 2 halves together. Standard set of double shielded ball races needed (forget sizes but you should have loads of different ones on the van anyway. :wink:)
The vital components required, apart from bearings, are: –
428662 Water Seal (Shaft)
264574 Tub Gasket Kit
Then you’re all set…….BRING IT ON!!!!
