im attempting to replace bearings on this mod is there any tips to getting the outer drum appart theres a few torx screws then the rest of the tub is clipped together ive not started yet cos the clips look a bit fragile so i thought id ask the question b4 i screw it up!
and can the bearings and seal be obtained on e-shop it just shows the half tub and seal.
The clips will need to be cut off mate. If you order a new seal , it should come with extra screws and these are used to secure the tubs together…..although , tbh , i’ve only ever changed the complete rear tub , never knocked the bearings out.
