Bosch WAA24161GB/01 – Unexpected heating fault
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Bosch WAA24161GB/01 – Unexpected heating fault
  • #77505
    aqua_serve
    Guys,
    Using my fault code guide I’ve diagnosed a fault on this machine as an ‘unexpected heating fault’ however after giving the machgine a once over I’ve not come across any faults on components, is this a module issue?
    Any advice would be appreciated.
    Mark
    #402401
    aqua_serve
    Re: Bosch WAA24161GB/01 – Unexpected heating fault
    Guys,
    Hate to try and get my post back to the top of the list but really struggling with this. Bought a new PCB as couldn’t trace the problem and it hasn’t solved it. The smallest bit of advice would be appreciated.
    Mark
    #402402
    wizard
    Mark,not something I’ve come across on these, but I’d be checking insulation resistance of heater & motor. Wiz
    #402403
    Not having a fault code guide can I ask what does the guide suggest is “an unexpected heating fault” when it’s at home?
    #402404
    ray.t
    I had one of these today, same machine same fault.
    Customer told me it got stuck in a wash cycle and then it wouldn’t do anything apart from flash the wash light.
    I checked through the machine when I was there and couldn’t find any faults. I was about to give up and saw the note in my book on how to reset the Bosch machines after the brush change and thought I might as well give it a go.
    The machine started to work again, I don’t know if it was just a fluke but it was working when I left.
    One thing I did notice though was even if you select a spin or the drain cycle it does light the wash light until you press the start button then it lights the spin light
    Cheers,
    Ray
