bosch waa24171gb
  • #66650
    tedd
    hi,went to w/m today wont start.the pin come out of handle which was broken so replaced but still no joy.the wash light flashes then the rinse light joins.suspect door interlock. any other suggestions regards tedd
    #364766
    A1engineer
    Re: bosch waa24171gb
    could well be door lock, just check it doesnt just need the fault code reset tho, turn the dial to off, then to 6 oclock. hold in spin button and turn 1 click to 7 oclock, let go of spin button. turn back to off then on again and give it a go.
    HTH
    Kev
    #364767
    simonb
    I remember needing a reset to a Bosch when changed brushes sometimes needs a few attempts to get it to reset so stick with it, seems strange though with only mechanical fault? Tried simulating the pecker action with insulated screwdriver?
    #364768
    jimluxe
    Check that the connector plug to the interlock has not come out (had a few of those problems)
    #364769
    tedd
    thanks for all your replies,i will look into these many thanks tedd
