Hi folks. Just ata Bosch WAA24171GB/01 FD 8805 02190. Rinse LED flashing on switch on. Changed brushes completely worn. Still got LED flashing, do I need to go through cancel procedure? Tried holding buttons and going to six o clock then seven oclock. May not be the sequence for this model.
Thanks in advance.
Try holding in the start button for 3 secs and turning the selector switch one click Anti-clockwise ( i.e 12 o’clock to 11 o’clock ) This is the way to enter the test programme.
….and the Rinse LED flashing is indeed a fault in the drive circuit so i think you’ve got the right component. Only hope the motor’s not goosed .
Thank you again Nomad Paul, what would we do without you.
I tested the motor carefully so hopefully I can now get the customer washing again.
Thank you. 😀
Hi Chris. It was only the motor brushes, but cancelling the registered fault was where help was needed and received from Nomad Paul.
So another one to make a note of folks. 🙂
